I'm working on fixing up my White Water , which has always seemed to have one problem or another.
I don't *believe* this issue is related to battery leakage, though there was some in the past - I have since installed NVRAM.
I've had someone shop the boards previously; he repaired around 10 breaks on the board.
On to the current issue. The Left Trough was not registering closed, so the game registered a missing pinball AND would feed two balls to the shooter lane if you tried to start a game.
I traced everything in the column (7) for connectivity - no problems.
I traced everyting in the row (8) for connectivity - no problems until I made it back to the trough. Someone had swapped the Center and Left Trough - meaning the Center was now on R8 and the Left was on R7.
Seemed like any easy fix - swap them so they are on the correct rows. Which I did.
That was incorrect. The game started fine (though it thew up a sound board error on first boot but never again) and didn't feed two balls, but now NOTHING on row 8 works, and half of column 2 (from row 4-8).
Checked fuses, no problems there. Swapped it back to see if that fixed the problem, no change.
Any insights?
