(Topic ID: 232859)
Tech - WH2O switch question
By PinballJeff
5 years ago
#1 5 years ago
I'm on the home stretch on getting my Whitewater back together thanks to this group and especially Mike Schudel. The current question is with a switch in the ball trough. Switch 76 (right trough) wire form seems to be hanging up on the eject cam assembly. If you look at the second picture below, you'll see that it's on the right side of eject cam. Can anyone advise if that is correct? I'm thinking that it needs to be bent to be on the left side.
Thanks in advance,
Pinball Jeff
IMG_3605 (resized).JPGIMG_3605 (resized).JPGIMG_3606 (resized).JPGIMG_3606 (resized).JPG
#2 5 years ago
Quoted from PinballJeff:
Thanks in advance,
Pinball Jeff
[quoted image][quoted image]
Correct!
DSC_2345 (resized).JPGDSC_2345 (resized).JPGDSC_2346 (resized).JPGDSC_2346 (resized).JPG
#3 5 years ago
Quoted from Davi:
Correct![quoted image][quoted image]
Thanks for the confirmation. I'm thinking that I've got a switch issue in the trough as it's feeding two balls into the shooter lane. I went through switch edge and 15, 78, 77, 76 & 53 are all registering. Any thoughts of what would be causing the multiple balls kicking out?
#4 5 years ago
Any of the switches in there not working properly or the shooter lane switch will do it (or wrong amount of balls).
Did you test with balls, with the PF in correct position?
#5 5 years ago
Quoted from TheLaw:
Playfield was in proper position. I've got the apron removed and controlled a pinball with a magnet sliding it down the trough in which it set off all switches properly.
#6 5 years ago
Little more information in case this helps. Before when playing the game it would get confused and end a ball while it was still in play. I figured something was going on in the trough and when I looked closer noticed that the eject cam wasn't responding back to home after kicking the ball to the shooter lane. Part of that was adjusting switch 76 as mentioned above, but the eject cam was still slow to return not allowing balls to progress down the trough. I ended up changing out the spring for the eject cam to something stiff so that it goes back to home quickly. After making this change, I'm now getting 2 balls kicking into the shooter lane. Again, tested the switches and all 5 are reading properly.
#7 5 years ago
Pesky Diodes?
#8 5 years ago
Quoted from TheLaw:
Pesky Diodes?
Can they be tested?
$ 40.00
Asheville, NC
7,600
Sugarloaf, CO
$ 119.99
Cabinet - (Alt) Translites
FlyLand Designs
Nezzy's Pinball Prints
$ 12.95
Pinball Pimp
$ 12.95
$ 9.95
$ 1,059.00
$ 27.95
$ 329.99
Pinball Z
$ 69.50
7,800 (OBO)
Cincinnati, OH
$ 34.99
Rubber/Silicone
NO GOUGE PINBALL™
Castle Rock, CO
$ 225.00
FlyLand Designs
$ 5.95
Mitchell Lighting
$ 189.00
Playfield - Plastics
Starcade Amusement
$ 60.00
$ 399.00
$ 9.95
Mitchell Lighting
YouBentMyWookie
$ 10.95
$ 225.00
Professor Pinball
$ 84.99
FlyLand Designs
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/tech-wh2o-switch-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
