I'm having issues with my TZ's right flippers being weak. This is what I've done so far:
* Checked all fuses with meter and pulling one end out.
* Rebuilt all flippers.
* Cleaned Optos
* Replaced Fliptronic board (based on a pinside thread with similar issues) with a Pinled (I&II) board, although when I replaced the board it I blew a fuse on the main board. Emailed tech support and told me to pull all fuses on their board and put them back in one at a time. I did this and the flippers worked, but still with weak right flippers.
* swapped opto boards--I did this and still weak right flippers, then the right side went dead after a coulple minutes of play. No blown fuses. I switched opto boards back again and both sides worked but no solution to the problem.
I am not a tech guy by any means, so I'm at the end of my knowledge with this, but my thought is that I should have bought a Rottendog board instead.
Any suggestions?
Thanks,
Greg
