The upper right flipper on my TZ just stopped working today. I turned the game on and the 2 left flippers and the bottom right flipper worked normally, but the upper right flipper isn't working. After playing for a few seconds the upper right flipper started to work as it should.
I turned the game off and let it sit for awhile and then turned it on again and the upper right flipper is not working again. So now I cannot get the upper right flipper to work at all when the game is just turned on or when it has been on for several minutes.
I have GLM flipper boards in my TZ and have had them in my TZ since January of 2008 and they have been very reliable. I replaced my GLM flipper board with another new GLM flipper board from my parts stash and still the same result where the upper right flipper doesn't work. When the right flipper button is pressed all the way in both LED's on the GLM flipper board light up to indicate that both flippers are activated (lower right and upper right).
I checked out the coil for the upper right flipper and it operates smoothly as it should. I can manually articulate the upper right flipper without any binding at all. The flipper coil lugs look very solid at the lug solder points so I am not sure what my next move is, but I eagerly await any and all advice from this knowledgeable group.
Thanks in advance for any guidance that is forthcoming.
Gord
