Hello folks,
Just finishing up a TZ resto and am having two problems that I am looking for insight on.
I just installed a new Ingo clock board and it is acting very funny. On start up it turns very fast in only forward and then tells me that the “clock is broken”. I went into the clock test menu and it doesn’t matter what section I am in on the clock test menu: “The clock is stopped”, “Forward fast”, “Forward Slow”, “Reverse Fast”, “Reverse Slow”, (any of them) the clock is actually moving very fast in the forward position and won’t stop unless I exit the test menu. In the test, it's registering all the optos correctly the hands are passing through as far as I can tell (moves very fast) and showing the correct time. In the solenoid test, "Clock reverse" doesn't do anything but all other solenoids operate normally
I also have a flasher problem:
Flashers not working: (inside ramp, upper right flipper, gumball hi, mid & lo, upper right ramp).
They are all tied into J107-6 but so are "bumpers", "Power payoff", "mini playfield", and "upper left ramp" and they are working fine so I don't think it's that leg. According to the manual the other leg for these flashers is spread across three other connectors, J124-5, J4- 1 through 5 (which has to be wrong because 1 and 3 are empty), and J3-5 (again, has to be wrong because it's empty) so I am skeptical about it being tied to all three (although 2 are on the 8 driver board)
Any help would be appreciated.
Thanks,
Jesse
