(Topic ID: 131468)
TECH - TZ Ground Row Short/IC issue. Help needed. **RESoLvED**
By gambit3113
8 years ago
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 8 years ago by terryb
#1 8 years ago
TZ - here is the history. Hitchhiker Switch 52 acting up, turns out the arm is off on one side and it is wedged up against the side of the slot. No biggie. Of course, I went in with the power on, like I moron. On the way back in to install switch, my hand contacted the tab on the coil for the ball diverter/magnet/gate thing that stops you from going to the power PF when not lit. Yikes. Worst shock I have ever took from a pin. I was holding the switch while I did it. Game reset and came up with Check Fuses F115 and F114. Crapola.
F115 was blown - So I just went straight to U20 and U14 (they smelled cooked). New U20 and U14 installed, and the game booted up, but random coils were firing and I got a buttload of switch out and row short errors. Went straight to U18 and U19 and replaced them with (now socketed!) 339s. Now the game comes up "Ground Short Row 1 is Stuck Closed". But I already replaced these ICs. If the 339s were bad, would that have possibly fouled the new U20? I just don't think there is anything shorted to ground on the game. I know what I did in sending the high voltage up the switch matrix, but it went through me into the switch and up to the CPU. Nothing shorting now.
Should I throw another U20 in there?
#2 8 years ago
just disconect the wires to the playfield from the cpu if you then have no ground fault you know you have a problem on the playfield if problem is still there then its back to the drawing board with the cpu
#3 8 years ago
Well, pulled the connectors to the PF off and get the Check Fuses 114 & 115 message. New U20 no help. Going back to U14 now. Going to socket new ones all around this time, but the problem is clearly on this board.
#4 8 years ago
No dice. Back to the laundry list of shorted rows, clock broken, switch errors, etc.....
Crap
#5 8 years ago
Game off and row connector removed, check for continuity from each pin on J208 to ground on the cpu.
#6 8 years ago
Quoted from chris_brim:
Quoted from gambit3113:
That will happen on some games. Start the game first and then remove the row and column connectors and see if the ground short goes away. If it does not, then also pull J212 and see if that helps.
It's easiest to pull the row/column connectors about 1/3 of the way off before starting the game.
#7 8 years ago
Jumping J207 to J209, I find that I get normal response and switch activation on each pin. Nothing out of the ordinary registering there.
#8 8 years ago
After a good 12 hours and soldering in sockets like I never have, I found the issue. U20, U14 and all 3 Opto Board 339s were torched. Running smoothly now. If you run 50v into the Switch Matrix of a TZ, the under PF Opto Board ICs should be on your radar. Don't run 50v to the Switch Matrix in the first place, you jackanape.
#9 8 years ago
That is the best plan.
Good job of troubleshooting.
$ 12.95
$ 49.99
$ 12.95
$ 14.95
8,500 (Firm)
Milwaukee, WI
$ 24.00
Various Novelties
Pinball Photos LLC
$ 129.50
Corona, CA
$ 125.00
$ 45.00
Just 3D Mods
$ 109.99
$ 63.00
$ 1.00
Pinball Alley
$ 43.99
Lee's Parts
$ 69.00
$ 6.00
Arcade Upkeep
10,500 (OBO)
Seaside, OR
$ 19.95
pinballmod
$ 62.00
$ 359.00
NO GOUGE PINBALL™
$ 29.95
10,000 (OBO)
Mount Pleasant, WI
$ 250.00
Professor Pinball
Pinball Photos LLC
$ 73.00
Pixels Arcade Games
$ 115.00
pinballmod
This page was printed from https://pinside.com/pinball/forum/topic/tech-tz-ground-row-shortic-issue-help-needed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
