I am out of ideas, so I am turning to the experts! I have a recently purchased TOM that has a problem with the trap door. It tries to raise up, but never gets more than half way before it immediately drops back down. It never gets high enough for the low power "Hold" circuit to hold it up. If I manually raise the trap door, then the hold circuit will hold it in place. The previous owner said the problem was there before.
I have rebuilt the solenoid assembly with a new A-20099 coil, and metal frame, to no avail. (yes I have read about some stainless steel frames having problems, but this problem was there with the old original frame.) I have also changed out the Power driver board with a known good one, again to no avail.
If I manually ground the driver transistors for the low and high power to the coil, the trap door works perfect. It seems to be that the software does not turn on the high power driver long enough to raise the trap door all the way.
I am running 1.2 software, not 1.3 which is the latest. Could this be a problem? I also have not tried a stronger coil in place of the A-20099 coil.
I am running out of ideas. Any helpful hints would be greatly appreciated.
