It's good that you're cautious. If you've got some old salvage parts around, give this method a try and see what you think. I know it sounds aggressive but it doesn't cause any damage to the switch blades or contact points, and it works like magic.
I've personally been using this method for over 15 years and have cleaned literally tens of thousands of switches. I've never messed up even one switch contact or bent one switch blade. I've used it on all kinds of EM switch stacks - very small to very big relays, motor switches, relay banks, score unit switches, flipper switches, EOS switches, etc.
I use a medium speed setting of the Dremel. I've never tried cleaning contacts with the tool running at top speed, so I suppose there could be some risk if someone were reckless enough to do that. As with any power tool, there is an expectation that you will pay attention to what you are doing and use good judgment.
For 100% disclosure, it's true that I did run into one issue with this method. This was on the older Gottlieb "R" type relays (the ones from the 40s and 50s made by Potter & Brumfield). These relays have rather delicate pigtail wires that attach the armature switch blades to the solder lugs. The Dremel brush snagged one of the pigtail wires and ripped it loose - a good example of not paying attention to what I was doing. Other than that, I've never had a problem with this method.
- TimMe
