(Topic ID: 250615)
Tech: This Getaway is KILLING me!
By fireball2
2 years ago
  • 40 posts
  • 18 Pinsiders participating
  • Latest reply 1 year ago by fireball2
#1 2 years ago
Please just shoot me now. This thing has had me running in circles and pulling my hair out like a noob for weeks.
Problem: HSII, The Getaway, locked on shooter coil.
Current Situation: Brand new MPU AND SDB. Brand New mini aux hi-current board that supplies extra current to that coil. Coil tests 3.1 ohms as it should. Transistor and diode on NEW SDB replaced, just in case. Connectors at sdb and aux board replaced. Ribbon cable from mpu to sdb replaced. All switches on shifter good. (I disconnected the shifter--no dice.)
WTF? Please. Someone throw me a bone; give me SOMETHING else to try!
#2 2 years ago
Quoted from fireball2:
Does it lock on with the P/F in the raised position?
#3 2 years ago
I like where Grumpy is going with this.
#4 2 years ago
Remove coil and see if wrapper is worn shorting to bracket.
#5 2 years ago
Quoted from pinballplusMN:
Happened on my No Fear. A stray coil winding was just grazing the bracket and grounding out.
#6 2 years ago
Quoted from GRUMPY:
Fixed a HSII like this once....when in lowered position habitrail was touching grounded hinge bolt in cabinet. So happened a switch lug was touching habitrail, so it acted as one big conductor.
#7 2 years ago
Sorry Boiz! Does it with playfield up or down. Checked for short to habitrail. No dice. It ain't there.
Coil wrap is bueno. Nothing is touching.
Next theory?
#8 2 years ago
Coil have diode backwards? Disconnect coil measure circuit see if still activated?
Try to isolate what's mechanical based in nature (mech) and what's electrical (boards) and go from there.
It's def. locked on and not just activating, then (mechanically) binding?
#9 2 years ago
Id triple check your transistor soldering job
#10 2 years ago
Quoted from slochar:
Coil diodes are on sdb. Already replaced.
No doubt locked. Plunger slides back easily when power is removed.
Quoted from Rdoyle1978:
Did. Also, it's a new sdb, and it was locking on before I swapped out the transistor.
Keep 'em coming!
#11 2 years ago
Do Rottendog sdb's have predriver transistors?
#12 2 years ago
Do you have a logic probe? Next step is to check the data buffer ic chip....I believe the RD boards dont have predriver transistors...straight from the ic through a resistor to the power transistor.
As a quick test pull the connector associated with that coils ground signal. If it stays locked, short in pf. If it releases, board problem.
#13 2 years ago
Quoted from robertmee:
Yes. But all I have for a schematic is for the original board, not the RD. Which chip would it be?
I think that's j127, and I think we tried that and it stayed locked on... and I think it's the RD SDB I've been saying it's the board all along, but the tranny and diode tested good...
#15 2 years ago
If J127 is correct, and you pulled it, and it stayed locked on, then you ha e a short in the pf somewhere. I dont have the manual in front of me...which Q transistor is the shooter?
#16 2 years ago
#17 2 years ago
So much talent on Pinside. Awesome to see everyone help out.
#18 2 years ago
Quoted from zaza:
So from this diagram, remove j127...if coil stays locked on, then driver board probably ok...next it becomes harder because the j1,j2 high power board supplies both power and ground.
I would remove the wire from the j2, pin5 onnector. If coil stays locked, playfield short. If coil releases, then probably Q1 in that diagram is shorted.
#19 2 years ago
The machine is at a pinbrotato's house, so I'll have to wait until next weekend to go thru this list...
But, I think it releases if you disconnect either j107 or j127.
The diagram is of the mini high current board that we replaced with new. But I'm also pretty sure I tested that tranny too anyway. But not the diode!
Thanks, Dumbass! (I love saying that without fear of insulting!)
#20 2 years ago
I think I'm confused now
#21 2 years ago
Quoted from zaza:
Yeah, me too. Remove J127, If it releases, it's the main board. If it stays locked on, then it's something downstream...high power board or playfield wiring.
#22 2 years ago
Quoted from zaza:
Sorry Daddio... I had to go look at a buncha texts and I didn't have my glasses. I'm doing a lot of this by distance too, since the machine is 20 minutes away... I am pretty sure it releases if you disconnect either one: j107 or j127
#23 2 years ago
Then it's the main board....R86, Q52, pin 16 of U4 IC. Pull J127 so you're not locking on coil and with logic probe check pin 16 of U4. Compare it to the other pins in the diagram for the other coils. If pin 16 is different, then U4 ic is bad. If it is the same, then likely q52 is bad.
#24 2 years ago
Ok, when it releases as J127 is disconnected, the problem is most likely on the powerdriverboard.
#25 2 years ago
Quoted from zaza:
Could also be nothing more than a bad ribbon cable between the MPU and driver board...I would try flipping it over to rule it out.
#26 2 years ago
Quoted from zaza:
Umm... This is a good example of the tail chasing I'm doing on this one.
Quoted from Pin_Guy:
Ribbon Cable Replaced.
#27 2 years ago
I will have my pinbromigo do this tonight.
#28 2 years ago
Is there a diode on the coil? If so cut it off. I had that on my Getaway. Locked the coil on. Diodes should be on the board, not the coil.
#29 2 years ago
No, it's a matter of semantics. My apologies...by main board I meant the power driver board not the high powered sub board. We were talking about the same thing. U4 needs to be checked as I suggested which is on the driver board.
#30 2 years ago
I dont think you need to do this anymore. This was suggested when you said ealrier that j127 removal the coil stayed locked on. Then you changed that later that removing j127 the coil releases. Have to be as accurate as possible in descriptions otherwise we all go down chasing rabbits.
#31 2 years ago
Quoted from o-din:
Coil diodes are on sdb. C'mon Cowboy, I done sayed that allready...
Got it. That's top of the list. I really think it's the sdb, even though it's new.
I checked my texts with the owner. Removing EITHER J127 OR J107 releases the lock. Sorry. Like I said... I wasn't wearing my dollah sto' spex when I was reading the texts...
#32 2 years ago
No problem....at this point I would be leaning towards Q52 or U4.
#33 2 years ago
Q52 has been replaced and the new one tests good. I even replaced the diode on the sdb that goes with q52.
Aint nuthin left but U4... Fingers crossed
#34 2 years ago
Did you replace it with a TIP102? If so, that transistor is not what is used on the Rottendog power driver board and is not a compatible replacement part for that board.
Correct transistor is a 20N10L but a IRL540 can be substituted.
#35 2 years ago
what the hell is a pinbromigo?? and if it’s what i think, how can i as a self-respecting adult, believe anything you say going forward??
#36 2 years ago
I can't stop laughing
#37 2 years ago
I would have started by simply trying to isolate the playfield from the boards.
See if the control lead to the coil is testing to ground. If it is... you know it’s a short or up on the board. Disconnect the connector on the board and test again... if still to ground then you know it’s a short on the pf. If not... move further up the chain to the connector itself. Unplug and test the pins while the game is live.
A coil firing is simply the controlled lead going to ground... use that knowledge to test that condition... remember the transistors are just doing that job by cpu control.
#38 2 years ago
Quoted from zaza:
Nice, Zaza you're the best bro
You too Robertmee, you've both helped me a few times in the past.
#39 2 years ago
Finally got back to this! And...
Winner! U4 pin 16 shows waaaay different reading from the rest... Looks like we might be onto something! Gonna order and replace the chip and we'll see... But I think this is it!
1 month later
#40 1 year ago
Finally got back to this bad boi... Replaced u4, the driver transistor, and the diode. And we are 100% working!
Thanks to swanng for the stellar board work and to all you Boiz for the help!
