My theatre of magic trunk will intermittently shut itself down with trunk error. This intermittently happens after hitting the trunk with the ball moving. After running a trunk test, the trunk is fine again for a while then it intermittently happens again. It always stops in the same transition spot if it stop at all - while traveling counter clockwise from the magnet to the next panel.
When trunk is moving, it seems to move steady and fast. It does not move slowly or jerky. Nothing appears to be binding. I have done:
- replaced trunk opto board. There are no errors during test
- replaced the opto interrupter with the metal one.
- taken apart the gearbox and cleaned, regreased with superlube (after doing this, the problem seems less frequent and seems to ways require hitting the trunk while it's moving)
- I have run trunk test while wiggling the opto connector and wires several times and I cannot reproduce any issues while doing that.
- I've also replaced the trunk motor board on a last ditch effort.
I contacted kimballs pinballs to get a new motor since I've pretty much exhausted other avenues. He thinks the motor is probably ok since it is moving smoothly. He also thinks repinning the opto connector is a wasted effort since he says these don't go out often and wiggling it can't repro trunk errors.
Suggestions?
