I opened all of the switches (except switch #24) by unplugged every switch under the playfield that can be unplugged and unplugging the trough. No change.
Here is what I am seeing with ONLY #24 and #88 (the ghost switch) closed.
- If I close #68 and #64, #88 opens
OR
- If I close #68 and #63, #88 opens
I built the matrix switch tester (fun build!) and was able to verify that I am able to eliminate the problem when the playfield matrix is replaced with the tester, so it isn't on the CPU board.
I tested the voltage going into the drop target opto PCB and it was around 14.7V, which seems high for what should be a 12V supply. Not sure that matters.
I have replaced the diodes on the drop target PCB, and #63, #64, #65.
I can provide a video of the testing that helps.
