OK, got my Getaway setup yesterday and my nephew played a couple games while I did a couple other things around the house. When I walked up to him after a couple of games I noticed none of the controlled lights were working. I did some digging and found there was a jumper ran from the a resistor to BR1, presumably to bypass a damaged trace, that had broken. I resolder the jumper but still no controlled lights. I get no 18v at the 18V TP, and the 50V test point reads 78V. Is it possible that BR1 went bad? I tried to test it but had trouble getting the probe on the leads since I hadn't pulled the board since there were a couple connector pins bypassed by directly soldering the wires to the board. Tested all fuses and they all tested good.
Thanks in advance for any help.
Kim
