(Topic ID: 63441)
Tech: Tftc weak flippers
By bdaily1983
10 years ago
  • 9 posts
  • 4 Pinsiders participating
  • Latest reply 9 years ago by k0balt
#1 10 years ago
I know this has been covered. Just seeing if there is anything else I should check. Bottom flippers were pretty weak. I rebuilt them and added new eos switches. I cleaned the cabinet switches..although they still look bad. I will replace them next. It has a rottendog flipper board. I've reseated the connectors.
After this, the right bottom seems ok. I've had a tftc before both bottom flippers were a lot stronger. The right flipper can make the left ramp.
The left flipper is still a little weak. I can't fully make the vertical right ramp. It doesn't seem like its just using the holding voltage...just seems a touch too weak.
What next?
#2 10 years ago
I rebuilt them on my old TFTC and that right shot to the vertical loop ramp has to be absolutely perfect to make it the whole way. It's a VERY tough shot...are you sure there's actually a flipper issue??
#3 10 years ago
Yeah I'm sure it's a flipper issue. Ive had a tftc before and these feel sluggish.
#4 10 years ago
Ordered some cabinet switches and new bats. Hopefully this helps.
#5 10 years ago
For the DE Deger flipper theory, the EOS switches are normally closed, and should open only at the very end of the flipper stroke.
The flipper coil gets a short 50v kick and then the 9v hold voltage until either you let go of the flipper button or the EOS switch closes again (if the ball knocks the bat down) and gets another short 50v kick.
If the EOS switch is not closed, you only ever get the 9v hold voltage.
So for DE a missing/broken/maladjusted/malfunctioning EOS switch can cause weak flips.
RussMyers
Quoted from bdaily1983:
What next?
#6 10 years ago
Thanks Russ. They seem to be adjusted correctly. At the end of stroke there is a small gap. I just replaced these switches. I'm also getting the 40ms pulse on the flipper board (well I think I am. The led is lighting up)
The flipper doesn't feel weak weak...like a holding voltage trying to flip the ball...if that makes sense. Just too weak to make the right vertical ramp.
#7 10 years ago
Do you have the coil setting to "Hard" in the menu?
RM
#8 10 years ago
Quoted from RussMyers:
RM
I do.
11 months later
#9 9 years ago
hi do you solve the problem? i have exactly the same.
but i noticed the lefi flipper begin to be weak after one or more flip.
i mean the first ball hit is strongt.
condenser?
Metal-Mods
$ 18.95
$ 345.00
$ 18.95
$ 16.50
$ 18.00
Mitchell Lighting
Sparky Pinball
4,500 (Firm)
South Bound Brook, NJ
YouBentMyWookie
Playfield - Plastics
Mad Czar Games
Metal-Mods
$ 18.95
£ 32.00
PinballToys
$ 19.95
Mitchell Lighting
$ 64.00
$ 27.95
$ 12.00
$ 5.00
This page was printed from https://pinside.com/pinball/forum/topic/tech-tftc-weak-flippers and we tried optimising it for printing. Some page elements may have been deliberately hidden.
