(Topic ID: 255676)
TECH: Taxi Outhole Kicker and Flashers
By Tlamb
  • 24 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by Tlamb
  • Taxi Williams, 1988
#1 4 years ago
I did a playfield swap on my Taxi and upon my first boot up I realized I made a mistake. I mounted the solenoid under the apron with the lugs facing up and created a short. I checked all the fuses and all are good but I still dont have the the outhole kicker, as well as a few other and most flashers. Looking at the manual I am going to guess I fried Q33, and a few others.
All my pop bumpers work, both 3 bank, catapult, spinout kickout, bell, knocker, and slings. 2 Flashers work, I can list it is helps but can't remember which specifically off the top of my head.
Any additional direction or information would be greatly appreciated.
Thanks! Todd
#2 4 years ago
Yup test that transistor , I bet it took a hit
#3 4 years ago
Did you look under the play field for a fuse with a brown wire connected to it?
#4 4 years ago
Would it have stopped there? Or do I need to test further? Also, I what is the easiest way to test? I have tried a couple methods I learned online in the past but never seem to get conclusive results.
#5 4 years ago
Quoted from GRUMPY:
I will check. I missed that one. Thanks!
#6 4 years ago
Quoted from Tlamb:
I do not see any fuses or recall moving any fuses over. Only fuse under the PF is in the power box coming from the outlet.
#7 4 years ago
Just looked at the manual and it's f2a on the aux power supply.
#8 4 years ago
Quoted from GRUMPY:
I will take a look. I checked all the fuses for continuity and all were good but I will double check that one specifically.
#9 4 years ago
Looking good but still need to figure out coils and flashers.
Voltage at outhole kicker, but still won’t fire.
CB820872-4B42-429E-A3CF-898F19310157 (resized).jpegCB820872-4B42-429E-A3CF-898F19310157 (resized).jpeg
#10 4 years ago
Put the game in coil test and lock it on the outhole coil. Then take a jumper with one end connected to ground. Briefly touch the other end to the metal tab of the correct TIP for the outhole coil. Does it fire now?
#11 4 years ago
Quoted from GRUMPY:
No. It doesn’t fire.
When I boot the game, the spin out kicker and catapult fire though.
#12 4 years ago
Quoted from Tlamb:
Then you have a wiring issue. You need to check continuity of the violet/brown wire on the coil to the inner connect board, and from the inner connect board to the aux power supply and then to the cpu board.
#13 4 years ago
Would this cause it?
6A143FF4-3FD9-4E18-B2BD-1B35740D6226 (resized).jpeg6A143FF4-3FD9-4E18-B2BD-1B35740D6226 (resized).jpegD31B539D-758E-407F-B833-87FED373EB48 (resized).jpegD31B539D-758E-407F-B833-87FED373EB48 (resized).jpeg
#14 4 years ago
Also. The coils on the brown wire chain are only measuring around 9-10V.
#15 4 years ago
Quoted from Tlamb:
When you said you had voltage on the coils, I assumed you had 39 volts DC. Check for power on both side of F-2a and J-11 pin 4. What do you get?
#16 4 years ago
I get the same 9-10v both sides and at the pin.
#17 4 years ago
To note I also don’t have any voltage at F2C
#18 4 years ago
Quoted from Tlamb:
Quoted from Tlamb:
Check for voltage at both sides of F-2 or W-6. Not sure which you have.
#19 4 years ago
Not sure what you mean by F-2, or W-6
#20 4 years ago
Found it. It measures 40V on right and 10V on left.
#21 4 years ago
Quoted from Tlamb:
There you go a bad W-6 zero ohm resistor. Replace it with a paper clip or a lead from from a electronic component such as a bridge rectifier.
#22 4 years ago
Thanks Grumpy! It ended up being W6 on the power board. It is 0ohm resistor but guess it went bad when I shorted. Replaced with a jumper wire, now good!
#23 4 years ago
Playball!
#24 4 years ago
Thanks! GRUMPY
23C03581-ECFB-44B6-9E4F-06D4992A6240 (resized).jpeg23C03581-ECFB-44B6-9E4F-06D4992A6240 (resized).jpeg
$ 44.99
Pinball Shark
$ 899.00
$ 18.95
Gweem's Mods
$ 36.95
$ 18.95
$ 109.00
$ 17.00
Metal-Mods
$ 99.00
Cabinet Parts
Gizmorama Pinball
4,000 (OBO)
Bay Shore, NY
$ 899.00
$ 27.00
4,495
West Chicago, IL
Middletown, OH
$ 22.50
This page was printed from https://pinside.com/pinball/forum/topic/tech-taxi-outhole-kicker-and-flashers and we tried optimising it for printing. Some page elements may have been deliberately hidden.
