(Topic ID: 178484)
Tech: Tales from the Crypt: slow burn to boot - [SOLVED]
By cody_chunn
7 years ago
#1 7 years ago
Game died in the middle of a ball during a party.
My Crypt is slow to wake up when I power it up. Initially it does nothing, and the diag LEDs aren't right...
But if you let it sit, after a few minutes it says:
"NO...NOPE...NO PAY...NO PAYEM...NO PAYEM NO GAYEM!"
And then it stables out and works OK.
I have convinced myself I need to recap the Power Supply. Anybody seen this behavior in a DE and solved it?
#2 7 years ago
My DE Lethal Weapon 3 showed the same symptoms you are experiencing. Power supply capacitor C2 was leaking brown stuff. It is in the 5 volt circuit. Use a Digital meter to check the 5 volt test point on a cold power up. It will most likely be well below 5 volts and then slowly rise up to the point that the boards have enough voltage to work normally. Very common problem on those power supplies.
#3 7 years ago
Quoted from mikat11:
Excellent! Thank you for the confirmation. I guess maybe I'll short-sell it and just cap the +5 circuit. Now I feel better about ordering parts ($).
#4 7 years ago
Well, I had one of the jumbo 30K uF on hand that filters the +5V bridge so I replaced it, but same results.
You were exactly right: +5VDC test pin was 2. something at power up and when it crossed 4.2 or near it booted to attract and then stuttered through the NO PAYEM quote then ran normally. Gonna try the Power Supply Re-Cap.
#5 7 years ago
Those DE power supply boards are the source of many problems....my solution is to replace with an Xpin (some like Rottendogs too) and move along....IMHO....
3 weeks later
#6 7 years ago
Well, my first instincts were right. Re-capping the +5 supply circuit fixed it. Two of the smaller caps had some electrolyte underneath them. Could not tell until they were removed.
Had a little problem with the voltage regulator IC. Strangely, some of the legs don't have a solder pad on the bottom of the board and I had two open-circuit legs. Ran a jumper and took care of that.
I went from totally dejected after replacing the caps and IC and seeing the game get worse, to testing continuity and proving what was the problem, then applying the fix, and finally turning on the machine and it booted right up and played great.
Thanks for the advice guys...now go check my Gorgar and Firepower threads!
Playfield - Plastics
Mad Czar Games
$ 18.95
$ 345.00
Metal-Mods
$ 18.00
Mitchell Lighting
$ 18.95
$ 18.95
$ 64.00
$ 18.95
Metal-Mods
YouBentMyWookie
$ 12.00
£ 32.00
PinballToys
Sparky Pinball
$ 19.95
Mitchell Lighting
$ 27.95
4,700
Lake Elsinore, CA
4,500 (Firm)
South Bound Brook, NJ
This page was printed from https://pinside.com/pinball/forum/topic/tech-tales-from-the-crypt-slow-burn-to-boot and we tried optimising it for printing. Some page elements may have been deliberately hidden.
