(Topic ID: 206216)
Tech: taf upper flipper stuck
By Deadlander
6 years ago
  • 12 posts
  • 6 Pinsiders participating
  • Latest reply 6 years ago by Aflacjack
#1 6 years ago
Hi there have a TAF that the upper flipper is stuck on hold. When we tap the left Flipper the hold voltage stops and the flipper goes down. We have checked transistors on the Fliptronics board all appear to be good using multimeter. Any suggestions?
Al
#2 6 years ago
Next time it sticks, turn off the game. If it stays up you have mechanical binding. If it drops immediately after turning the game off you have an electrical issue.
From what you describe, it sounds mechanical.
Try playing a game again and when it sticks, turn the game off and report whether or not it dropped when the game turned off.
#3 6 years ago
Definitely not mechanical when you power the game off it returns down plus you can feel the hold of the solinoid when you wiggle it.
#4 6 years ago
I would start by cleaning the flipper opto boards, if that doesn't help swap the left and right boards and see if the issue goes away.
#5 6 years ago
Check soldering and diodes on the coil.
#6 6 years ago
Quoted from Pin_Guy:
TAF is fliptronics but doesn't have flipper opto boards.
Check gap and clean EOS switch on the flipper as well as flipper button switch. Compare to the side that's working. A binding EOS switch or cabinet switch, even though a mechanical issue, will act like an electrical issue once power is removed.
#7 6 years ago
Solved it replaced q15 and q7 on driver board fixed issue. They tested ok with multimeter but we guess one was leaking and causing the errant behavior. Thanks for the sugestions.
Regards,Al
#8 6 years ago
I had the same problem about 3 months ago. Did exactly what you did and it fixed it
4 weeks later
#9 6 years ago
I have this problem now as of last night. Turn on game.... Right upper flipper works right for a couple flips. Then stays up until the left flippers are hit for a few times. Then locks and stays unless I turn off the machine. Diodes all test good. Eos operates correctly. Looks just like the left one. Reflowed solder on all coils. Same issue. Going to replace q15 and q7 and see how that works.
#10 6 years ago
Quoted from Aflacjack:
Did you lift one leg to test ?
#11 6 years ago
Diode on the faulty coil tested bad. Replaced it and issue remains. Transistors being replaced tomorrow
#12 6 years ago
Replaced the tip102 flipper transistor and all is better. The old transistor tested as working but apparently failed under a load. Thanks for the help.
$ 29.99
NO GOUGE PINBALL™
$ 145.00
Twisted Tokens
$ 1,059.00
11,000 (OBO)
Hanford, CA
$ 29.95
$ 95.00
Twisted Tokens
Twisted Tokens
20,000 (OBO)
Oakdale, CA
$ 329.99
$ 55.00
Twisted Tokens
$ 65.00
arcade-cabinets.com
10,000 (OBO)
Roselle, IL
$ 29.00
Pinball Photos LLC
$ 25.99
Lee's Parts
$ 159.00
$ 9.95
$ 62.00
$ 320.00
Avid Creations Wireforms
$ 140.00
pinballmod
$ 31.99
Lee's Parts
Various Other Swag
JK Pinball
$ 26.99
Lee's Parts
26,000 (OBO)
Auckland, NZ
$ 28.99
Lee's Parts
This page was printed from https://pinside.com/pinball/forum/topic/tech-taf-upper-flipper-stuck-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
