Hey Guys...finally had a chance to look at Thing and all tests register correctly. I did reseat the connector that comes out of the box. Still nothing. I then cleaned the metal bolt that pick up the ball to see if there was something causing it not to hold on the way up. No luck.
I then ran it with the box lid open so I could see what it was doing. Nothing in the way or hitting the ball. It appears to just to loose its magnetic hold (or falls right off) right after it starts its way back up.
I tried removing the box but I really can't figure out how to get to the screws that go up the back of the playfield. I did remove the two on the front and took a look but could not see much and would really like to get that entire box off. Do I need to remove the playfield to get to those screws back there?
Thanks again for all your help
