I'm looking for tips on how to get a neighbor's TAF kick-out back into tip top shape.
Have you ever tackled a slow-ejecting cellar before?
These are my ideas. If you have any suggestions, fire away...
Current symptom:
Ball fires out slowly and hits the top of the sling, then bounces casually to the left flipper.
-mof
Possible causes:
1. assembly has shifted and no longer aims correctly (how would I view this? seems fine looking vertical from underneath)
2. trough area is very dirty inside, and the drag slows the ball down (fixed it, and it helped just a little)
3. solenoid assembly is very dirty and it doesn't kick well (it had a little drag, now it has a little less drag)
4. solenoid not getting enough power (75 vdc, looks good)
5. solenoid sleeve is old and dragging (nope, it's metal) <=== replaced with plastic sleeve, and it's fixed!
6. check switch (they are all good, I adjusted one)
7. check rubber plug at the end of the plunger stop (looks old but intact)
8. check for correct coil ae-23-800 (it's the wrong coil) <===
9. broken weld on kickout (this is messing up the aim, not the strength of the kick)
