Symptom: when the left flipper is pressed, it fires the switch on the left rollover
No switch issues reported ( I think), have buzzed test switch - it’s open.
Tried:
Switch mostly works when triggered manually as does others but need further testing
Swapped out alltek mpu board - same issue.
The switch does not test closed.
I temporarily swapped in an alltek mpu and it has the same issue.
I see an auxiliary lamp driver board comes into play with these rollovers.
Not sure where to next
Thanks in advance
