(Topic ID: 140178)
SOLVED: TECH: STNG Infamous Left Cannon Issue
By smokey_789
6 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by smokey_789
#1 6 years ago
Read every post here regarding left cannon issues. Mine is a little different: Power up, left cannon kicker immediately deploys and stays out, cannon proceeds to rotate continually until I manually pop the kicker back in, cannon immediately returns home and all is well. Cannons operate perfectly in game play. I checked the optos and they seem a little dim, but if they work in game play, I would rule optos out.
#2 6 years ago
Its going to be the coil sleeve. They are worn and the plunger sticks. Mine did that as well and once I replaced the sleeves, they the problem went away.
#3 6 years ago
Check the coil bracket in there as well--replace while you are at it.
#4 6 years ago
Thanks! Great advice!
#5 6 years ago
Kinda wondering why the kicker pops out at startup anyway. Part of the startup test sequence?
#6 6 years ago
It is testing the opto when it kicks out... I think. : )
#7 6 years ago
Replaced coil sleeve and adjusted the coil stop--it was a little skewed--there are slots in the stop to center it up--I believe it was binding ever so slightly. The adjustment along with new sleeve fixed what was a mechanical problem. Thanks for the advice and hope this helps others.
