Hi there,
Got a stern Galaxy that has a flaky switch for the galaxy hole kick out. The ball will randomly get stuck waiting for the galaxy kicker to work. I've check the switch numerous time and it is mechanically working correctly. During a game you shoot the Galaxy hole and occasionally the game will not acknowledge the switch. The game doesn't have a ball search mode so your stuck in the water. Once you turn off the game and turn it back on the switch works normally for a few games then acts up again. I'm wondering if I should replace all of the diodes associated with the wires attached to the switch (yellow-red & white-orange). I have already replaced the diode on the switch in question. Could one of the other switches have a bad diode causing this intermittent problem? Before I swap out 10-12 diodes I wanted to get another opinion as to what is wrong.
On another note I have a stern trident that randomly scores. I noticed that my Galaxy has had several of the brown caps cut. I'm guessing this was to address a similar problem. What purpose do these caps serve? Can I just cut them out to fix my random scoring problem with Trident.
Thanks for your assistance. I'm just figuring out these old sterns.. Al
