I just picked up a Space Shuttle that worked when I picked it up. I got it home and powered it up - the GI lights come on, but no displays. In the back box there is an LED with the number "7". Any ideas where to start with this?
Thanks.
A 7 indicates no 12 volts to the CPU board or bad game EPROM chips. A connector on the board may need re-seated or the chips re-seated.
But first check that you didn't mix the large black & white playfield connectors (check that the wire colors match up). Mixing those plugs up causes severe damage to the CPU board.
Quoted from mwsmith:A 7 indicates no 12 volts to the CPU board or bad game EPROM chips. A connector on the board may need re-seated or the chips re-seated.
Thanks for the reply. I did not unplug any connectors, so it shouldn't be that. Tomorrow I will try re-seating the connectors and chips as you suggested.
I found out that if you push the right button on the driver board, the displays will come on and it is in test mode. If you scroll through the all of the tests, you can start a game. The sound does not work, but I knew that. Would the sound not working be the cause of the error? Thanks.
Quoted from tbmi:I found that it had a bad sound ROM. A new one fixed it.
Well, I thought I had it fixed. The next time I turned it on, I got the code 7 again. I had to press the right button on the driver board again (although the sound does work now). It is doing some weird things like sometimes on the first ball the flippers and coils do not work and when the ball drains, it serves up ball 2 and all is well. Weird!
Quoted from tbmi:Well, I thought I had it fixed. The next time I turned it on, I got the code 7 again. I had to press the right button on the driver board again (although the sound does work now). It is doing some weird things like sometimes on the first ball the flippers and coils do not work and when the ball drains, it serves up ball 2 and all is well. Weird!
I'm debating trading this Space Shuttle for another machine. The playfield is in very good condition and looks to be clear coated. The cabinet, plastics and translite all look good. It does have a remote battery holder, new game and sound ROMs and I have a new uninstalled ramp that I would include. Once the issue I previously described is fixed, it would be a very nice example.
Open to trade offers - my only other machine is a Shaq Attaq.
You may want to post your location; that'll help you find local trades. Plus, you may find you have local pinsiders willing to help repair Shuttle. Shuttle is definitely a good game, and worth fixing up and playing for a while.
Quoted from Collin:You may want to post your location; that'll help you find local trades. Plus, you may find you have local pinsiders willing to help repair Shuttle. Shuttle is definitely a good game, and worth fixing up and playing for a while.
Ah, thanks for the catch, I forgot. I am in western Michigan, specifically Holland.
Your Space Shuttle is a Williams System 9 game. Pinwiki (a great resource) has this to say about error code 7 :
http://www.pinwiki.com/wiki/index.php?title=Williams_System_9_-_11#System_9_Games
"7 - System failure. Occasionally, the following components can contribute to this problem: U21 (4MhZ crystal); components in the IRQ circuit; broken leads on C9 (22uF) in the reset section; loosely seated ICs on the CPU board"
With that in mind, and since (presumably) the only thing that happened between working and not working was the game being moved, I would suspect an IC is loose or your C9 cap has a bad solder joint (or maybe the cap is failing.) The ICs would be smaller chips, probably socketed. I would suggest reseating those (one at a time, with the game OFF) and see what that does for you.
You should be able to pry the chips a bit loose with a small flat screwdriver, and push them back in gently with a finger.
Definitely agree with fixing Space Shuttle or seeking help. Worth spending some time on, unless you want to trade with me of course...
It's weird, because if I turn the machine on (after sitting awhile), it gives me the "7" code. If I open the coin door and then press the button the driver board, the machine will work without sound. If I turn the game off and immediately back on, then I the sound comes on and I can play normal games.
Space Shuttle is the pin that helped saved Williams from closing. They sold 18k of them and it started the pinball comeback for Williams. It's a great theme and could not have arrived at any other better time.
Quoted from Cheddar:Wow they sold 18k of the 7k made. I am shocked they got out of the pinball business
Ha ha too funny!
Quoted from tbmi:It's weird, because if I turn the machine on (after sitting awhile), it gives me the "7" code. If I open the coin door and then press the button the driver board, the machine will work without sound. If I turn the game off and immediately back on, then I the sound comes on and I can play normal games.
Are the batteries good? I know system 11 will not run right without batteries. I am not too familiar with system 9 but maybe a capacitor in the reset section?
Here is the information on it:
grandrapids.craigslist.org link
May also sell it outright but would like to get $1,200 for it.
It appears I may just get the board repaired and hang onto the Space Shuttle. Thanks for all of the interest.
Quoted from benheck:I had this issue on mine.
Replacing the sockets fixed it.
It looks like a socket was the culprit. Thanks!
This page was printed from https://pinside.com/pinball/forum/topic/tech-space-shuttle-does-not-start-up and we tried optimising it for printing. Some page elements may have been deliberately hidden.
