had this game for a few years, finally getting around to it, bought it non working.
just installed new power supply and new pinled displays.
any burnt connectors and pins were replaced.
press start, game throws random switches. tilt, ball trough switches, (so both kickers kick over and over), targets, "jackpot" collect switch, out lane switches, etc. 2 of the upper lane, etc.
they just score at random. it also adds credits and adds more players to play at random.
if i put it in switch test, rows 7 and 8 work fine. any of the switches in the other rows act goofy. example. if i press a single switch it will throw up a certain switch number, but if i press it again, it will be a diferent number, press again and another different number.
the only switches that behave properly are in rows 7 and 8 as i mention. so if i press a target that is in row 8 for example, if i press it 10 times in a row, the same exact correct switch number will come up on the display.
also, if i pull either connector (row or column for switches) from the cpu, it will not act up.
of course i cant play it ...lol.
if i press start and it acts all silly, if i quickly disconnect one of those connectors, it stops doing the random switch triggers...and sits properly in game mode.
thoughts?
