Hi all,
I've had my Addams Family table for about a year now but it's suddenly stopped kicking out the ball/ball out. Not being sure why this happens I entered test mode and tried the solenoid (Ball out/No.4). I found that you can hear the magnetism and see a tiny bit of movement on the spring but it stays closed. Sadly I'm a bit of a pinball rookie in terms of fixing. Nonetheless, in a desperate attempt, I replaced the solenoid in question and it still does the same. I've attached photos in the hope they will show an obvious problem. If anyone knows anything to try/check/fix I would be so thankful!
Chris
