I removed the head from my Atlantis that I recently purchased to move it into the basement and have reattached it (as I've done many times). Upon powering the machine up the first time, everything came on but I started smelling smoke. I found that the component circled below is the culprit as it was extremely hot (it's right above connector J12 on the main board). I double checked my work and everything looks good. Any suggestions on what is causing the issue?
// Error: Image 444141 not found //
**Solved - and I feel like an idiot. I had connector J2 plugged into J12. Ugh! Anyways, everything is working. Hopefully I didn't do too much damage.
