(Topic ID: 124686)
TECH: Roadshow delayed boot up
By Eric_S
9 years ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 9 years ago by Eric_S
#1 9 years ago
I have a Roadshow that I'm working on and I have an odd issue where there is about a 20-30 delay between powering the game on and the MPU booting up. When I got the game, it had no five volts so I reflowed all the header pins on the driver board and replaced BR2, C4 and C5 which cleared up the 5V issue.
Now, when I power the game on, it takes 20-30 seconds for the game to actually boot up the MPU. I replaced the thermistor because the old one actually broke in two pieces when I touched it. I thought I may have a problem with the new thermistor so I soldered in a jumper wire across it and it didn't make a difference.
On the MPU, the lower and upper LEDs stay on with the middle LED staying off. once it boots, the upper LED goes off, middle LED blinks as usual and the lower LED stays on. I measured voltage at the MPU and driver board on the 5V line. During the initial boot up, the +5V line will measure around +4.65 V and when the game boots up, the voltage jumps up to around 4.8V.
Any ideas? Once the game boots up, I don't seem to have any problems (no reset issues).
#2 9 years ago
Quoted from Eric_S:
I have a roadshow that I'm working on and I have an odd issue where there is about a 20-30 delay between powering the game on and the MPU booting up. When I got the game, it had no five volts so I reflowed all the header pins on the driver board and replaced BR2, C4 and C5 which cleared up the 5V issue.
Make sure you didnt add resistance in the circuit at the through holes to the filter caps and bridge rectifier.
#3 9 years ago
Interesting.
Disconnect everything else that uses 5/12V (follow the wire bundle) and then reboot.
Does it still take that long?
We are trying to see if another board is brining down the 5V.
Chris Hibler - CARGPB #31
http://www.Team-EM.com
http://webpags.charter.net/chibler/Pinball/index.htm
#4 9 years ago
Back in the old days a device was added to have a boot delay not to show the serial number. Was done because of sales outside sales territories. Maybe you have such a device?
#5 9 years ago
I thought of that by I think the OP is correctly calling the MPU LEDs flashing boot up. The device would only delay the display presentation.
#6 9 years ago
I don't think there is any device purposely delaying the boot up. The MPU will boot up and show the serial number when it eventually does boot up. I haven't had much time to look into this issue lately.
$ 63.95
4,900
West Chicago, IL
$ 19.95
$ 31.99
Lee's Parts
$ 1.29
Daddio's 3D Printed Mods
Bakersfield, CA
$ 79.00
Lighting - Under Cabinet
Arcade Upkeep
$ 85.00
$ 29.99
Lee's Parts
$ 26.75
pinballmod
Pinball Invasion
$ 11.95
$ 22.50
bdash's bits
$ 11.95
4,800 (OBO)
Richmond, VA
$ 109.95
PinSound
Slap Save Creations
$ 11.95
$ 9.95
This page was printed from https://pinside.com/pinball/forum/topic/tech-roadshow-delayed-boot-up and we tried optimising it for printing. Some page elements may have been deliberately hidden.
