(Topic ID: 257048)
Tech question about Stern spike coils operation
By Crrispy
7 months ago
  • 11 posts
  • 6 Pinsiders participating
  • Latest reply 7 months ago by Crrispy
    #1 7 months ago
    Hi,
    I want to trigger a mod with a coil on my Ghostbusters. I've added a small 48V relay soldered to the coil (captive balls release on the left), and the relay contact triggers the mod.
    Problem is that it works perfectly fine in coils test mode, but not in game, and I can't understand this. Is the voltage used ingame lower than in test mode? That does not make sense. Really strange.
    #2 7 months ago
    Quoted from Crrispy:
    Hi,
    Yes voltage is lower during a game,Voltage is higher in test mode
    #3 7 months ago
    Quoted from pinmike:
    Thanks. I have to measure this, seems a bit strange. Could explain why the 48V relay is not activated during game, but...
    #4 7 months ago
    Spike uses a variable power supply system. I would be careful about hooking anything additional up to the high voltage circuits.
    #5 7 months ago
    When a game is in test mode the high voltage would be higher because the high volt signals are activated one at a time.During a game all the high volts are being used at the same time
    #6 7 months ago
    Quoted from kermit24:
    Yes that is right
    #7 7 months ago
    Wondering how you are triggering the relay. positive to 86 or negative to 85?
    #8 7 months ago
    The voltage shouldn't matter. Arent you providing separate voltage to the relay and then getting ground from the coil?
    #9 7 months ago
    I've just put the relay coil in parallel of the playfield coil. These are those small blue relays, the power they eat is very very low.
    #10 7 months ago
    The small relay current is a few tens of milliamps, negligible compared to coil current so it is very unlikely it could mess up the circuit.
    Maybe you should use a 24V relay, with a suitable series resistor to get reliable operation during game. Measure the 24V relay coil resistance, try series resistor of half the measured value.
    #11 7 months ago
    I've ordered 12V relays because I also want to test the coin meter/knocker output @ Node1/CN3, have no 24V in stock.
    Could also work on a coil with a good calculation of the resistance.
    To be continued.
    $ 159.99
    $ 109.99
    $ 5,899.00
    Operation Pinball
    $ 13.50
    Playfield - Plastics
    $ 58.00
    $ 139.00
    Sparky Pinball
    $ 28.75
    The MOD Couple
    $ 29.00
    Filament Printing
    $ 27.99
    Williamson Pinball Mods
    Gameroom Mods
    $ 60.00
    RobTune
    Metal-Mods
    $ 29.25
    The MOD Couple
    $ 39.99
    Lee's Parts
    Flashinstinct
    $ 200.00
    Maple Street Sign Shop
