So I am fairly new to the hobby and just acquired a T3 (Thanks PDXMonkey!). Loads of fun and everything works perfectly with the exception of the 4 flashers on the back panel near the T-X and Arnold. Upon closer inspection, I noticed that some of the red domes over the flashers were melted a little. Not a good sign. Got in the back and 2 of the 4 bulbs were shattered and 1 slot was empty. Okay, just need to add some working flashers in there and we should be good. Nope. Even with good flashers, still no joy.
Yesterday, I picked up a DMM and I must say that I was pretty intimidated by this thing. I am fairly mechanically inclined but when it comes to circuitry, diodes, capacitors and fuses, I am out of my element. But if I want the T3's RED Mode to really pop, I should go deeper. First, I pulled all the fuses out and did a continuity check on all of them. All good. What next. Time to check the wiring. This was a bit more of a struggle with trying to get to the back panel of the play field while connecting the other end to the molex connector. After some time, I indeed did find that the wiring was consistent in the lower part of the play field. Now to check from the molex to the back box. Wiring seems good and we have continuity. I remove the molex from the board and start visually inspecting.
Then I see it. Something doesn't look right. Q30 looks a little browned and cracked a little. This has to be my problem. Such a great sense of accomplishment to know that I had no idea what I was doing but was able to just deduce my way through it. So if you are a rookie, a DMM is a MUST.
Anyways, on to my question. Not having much experience with soldering, is swapping one of these (also, can someone give me a name for this, I would be grateful) too difficult if I had the right tools? (Decent solder iron, solder sucker, etc.) Is this a DIY job or shall I ask some pin repair guys in the area to help me out? I have done all of the leg work and know exactly what needs fixing. I would just hate to slip and "ruin" the board or something.
Thanks for the advice!
