Quoted from xfassa:pinstyle - I think the speed of the ball has a lot to do with it. It doesn't seem to be an issue at slower ball speeds. I am starting to wonder if my flipper coils are too strong. My current coils are correct according to the manual but stepping them down in power might help.....
I also purchased a used set of Getaway ball guides. If I cant figure it out, I will replace my current ball guides and see if it helps. I really want this game to play well. Too much time/money invested to leave it as is.
Same problem here, it is fine at lower speeds, just the perfect clean fast balls have an issue. In the curve of my guide there is definitely marks from the ball climbing up the guide and judging by the marks made, it looks like the ball has been doing that for a very very long time. I'll have to check the right side. I have the problem on the right also but nowhere near as bad as the left. Maybe one in 30 or more on the right is rejected.
I do see the bend in yours he is talking about. I guess it is possible that is what is causing it. I have my doubts though considering the ball trails I can clearly see on my guide. They start well before that bend on yours. I've played around with my switch mostly, thinking that was the issue. When I get to it again I'll do some testing and see if I can figure it out. If I do I will post the results.
Something I thought about is you could remove your switch again and put a piece of tape over the slot for the switch just to rule out the ball becoming airborne rolling over that slot. Just a thought....
