To simplify my question, my back right tower is cut in half. Is it possible to attach the castle tower (pic attached):
to the castle lower base (pic attached):
I also need to remove the old castle bottom half that is cut in half but still attached from that lower base assembly circle. The stationary tower is removable very easily, but the ones that are attached to the exploding portion of the castle aren't coming off and I'm afraid to pull too hard.
I can't find any parts store online that is selling the parts already molded together.
*UPDATE FOR POSTERITY*
The previous owner must have glued on the old castle tower to the lower base. Removing the castle completely gave me enough leverage to remove the broken castle base and install a new one. After about 10 castle explosions, the back right castle tower came off again (kind of cool, given the game's theme). I re attached it to the base one last time using double sided, thin, tape on the interior lining wall of the tower itself. Hasn't come off since but if it does, I'll probably go the glue route myself to keep it on.
As for the leaning tower, we drilled a hole through the black lower assembly like a previous poster, and attached another spring to keep it straight. So it's basically like the other 3 small towers with its own spring.
