Turned on my IJ tonight and noticed the controlled lamps were acting strangely. When one was supposed to light, multiple lit instead. I went into single lamp test mode and found the following:
Test 11 lights lamps 11, 21, 31, 41
Test 12 lights 12, 22, 32, 42
Etc. down to 18 lights 18, 28, 38, 48
Test for lamp 21 lights 11, 21, 31, 41 and so on down column two. This pattern continues for the first four columns.
When I test a lamp in column 5, it lights the correct lamp, plus all the lamps in the same row in columns 1, 2, 3 and 4.
A lamp in column 6 lights the correct lamp, plus the same ones in columns 1, 2, 3, and 4, etc.
So basically each lamp lights the correct one, plus all of the lights in the same row, in columns 1, 2, 3, and 4.
If anyone can offer advice or a strategy on how to begin diagnosising and fixing the problem I'd greatly appreciate it! I'm willing to try/learn anything you suggest, but don't have the expertise that many of you have to know how to begin to root out the problem. Thanks for your time.
