So before I even got this machine, I knew all about the sound issues that later Sega's had where almost all ran in mono and some machines even only had 1 speaker in them. I even read about the missing channel off the soundboard entirely (http://www.pinballnews.com/learn/speaker/).
Anyway, after looking in the head of my ID4, I came to realize that not only do I have 3 audio channels on my board, I also have 3 speakers (sub, left and right) which is good. Now I am thinking about simply upgrading the garbage stock speakers to the Pro Pinball set. I have no problems doing this but my only hesitation is that it seems one of the channels on the sound board is A LOT louder than the other channel. Obnoxiously so. I would hate to upgrade to a nicer speaker set only to still have the balance issues that currently exist.
Also, this obnoxious channel also hums when I hold my right flipper down which suggests to me some sort of grounding issue but I have no idea how to even begin troubleshooting that.
In the pics below, you can see all three channels on the sound board. Mr. Rude channel is on the set of white wires coming out of the molex. I am thinking that the white set and additional caps was added aftermarket and is the culprit. If this is the case, could the prior owner have put on the incorrect caps? I haven't attempted to match numbers or anything since I would probably have to take the board off to get a good look at it. My vision isn't what it used to be.
Any advice is appreciated.
