Title says it all. How should the flipper bat be aligned in comparison with the holes. Centered? Bottom of bat aligned with a toothpick? Thanks for any info.
Mike
Mike
Quoted from mikeflan:Title says it all. How should the flipper bat be aligned in comparison with the holes. Centered? Bottom of bat aligned with a toothpick? Thanks for any info.
Mike
Ours are centered. The flipper bat is in the middle.
https://pinside.com/pinball/forum/topic/aligning-flippers-rubber-on-or-off-flipper
And don't forget to adjust the up and down on the bushing so the flipper doesn't drag. They sell little flipper gauges for this, or a credit card works.
I've always done the toothpick in the hole with the bottom of the flipper resting on it - it should be in line with the inlane, an extension of it.
Quoted from pinzrfun:I've always done the toothpick in the hole with the bottom of the flipper resting on it - it should be in line with the inlane, an extension of it.
" the toothpick in the hole with the bottom of the flipper resting on it" That's for Bally/Williams, that doesnt work with Data East/Stern playfields - the hole is supposed to be in the dead center at the tip of the flipper bat.
The best alignment is as you said in the second part: in line with the inlane, an extension of it. (not for Gottlieb Sys 3 though, they are meant to droop a bit, in line with the biff bars)
This page was printed from https://pinside.com/pinball/forum/topic/tech-how-to-adjust-lower-flippers-on-the-simpsons-pinball-party and we tried optimising it for printing. Some page elements may have been deliberately hidden.
