Hi guys, I'm having switch troubles with the 4-bank drop target assembly on my Dr Dude (System 11).
All of a sudden the behaviour started where the bank would take one hit from a ball on any target and they'd all register as being it. And occasionally nothing would hit the drop targets but hits would be registered (indicated by the flasher and 'bling' sound when bank is completed).
My first thought was a bad diode so I took apart the assy, cleaned the optos, checked the diodes and they are all fine. I inspected all the solder points on the board and none looked to be in need of reflowing.
I put the assy back in the game to test after cleaning and the behaviour persisted.
In switch edges test the following happens:
If I drop target 4, it registers a whole bunch of 'target 4' in rapid fire. If I drop target 2 it registers it, but also triggers several 'target 4'. Other targets mostly don't register at all.
If I knock on the playfield near the targets I can get target 4 to register as well.
Question: should I reflow the solder points, or is the actual opto for target 4 (and possibly others) likely the culprit?
Cheers in advance for any help
