Problem:
Scared Stiff spider wheel not spinning.
Observations:
Opto checks OK
LED1 on D-12046 stepper motor board is ON
Motor shaft resistant to spin when powerd ON but will spin easily when powered OFF.
All connections/wires appear to be OK
All solder points/headers on board appear good
All fuses check and are OK
Update: Checked +12V coming into controller board and it is good
Update: Replaced Lm339 comparator. Did not resolve issue
Update: Unplugged J110 and grounded ylw/wht and grn/wht. Each condition yielded a motor response (twitch). Replace U3 next?
Options:
Coincidentally, Who Dunnit is next to Scared Stiff. Can easily swap stepper motors (to rule out problem with motor)
Update: Swapped out stepper motor. Did not resolve issue. Stepper motor acted the same (motor shaft resistant to spin when powerd ON but will spin easily when powered OFF)
Best Guess:
GUESSING the LM339 is bad. Again, just a guess.
Update: Replaced but did not resolve issue
Update: Potential issue with U3 chip. Next step is to replace the chip.
Helpful Links:
http://www.ufopinball.com/pub/D-12046.gif
https://pinside.com/pinball/forum/topic/scared-stiff-spider-wheel-problem
Anyone have ideas, please let me know. Also, go enjoy your 4th of July instead of scanning the Pinside threads.
