Hi Guys
Did a clean and wax on the machine and now have run into an issue. The coil on the advance unit seems to lock on and of course gets very hot to the point of creating smoke. Bad!!
I have a scheme for it and it appears that the advance coil is energized through what is indicated in the scheme as the " 1 Pt Re. I am assuming this is the one point relay or switch? I looked in the backbox and found th different relays for the ones tens hundreds and thousands and none are locked in and when the game is powered will advance each reel accordingly.
I think that the one point switches on this game are the roll overs in the center lower portion of the playfield. Confirm?
Anyone out there that could assist possibly?
Thank you all
G
