(Topic ID: 96521)
Tech Help Please: Scared Stiff
By JKirby
5 years ago
  • 18 posts
  • 6 Pinsiders participating
  • Latest reply 4 years ago by zaza
#1 5 years ago
Good Afternoon Everyone,
Working on my Scared Stiff - the spider motor won't spin. There are no schematics in the manual, so I'm hoping someone here can point me in the right direction.
What I know: The LED is lit, I'm assuming this means voltage. When I attempt the spider test it seems like the motor is trying to spin. I can hear it humming, and when I put the actual plastic pointer on it the pointer shakes as if it's trying to move. Please note that is a new motor. I took the cover off and the lubricant on there is still viscous and not dirty.
What can I look for to try to resolve this? Any help would be much appreciated.
Thanks,
Joe
#2 5 years ago
Measure voltage at the motor. If low it won't work, if right bad motor.
LTG : )™
#3 5 years ago
Just in case you need a new motor, look here for $14.95:
https://www.sparkfun.com/products/9238
I bought and install one and it worked great.
#4 5 years ago
Measure voltage at both sets of wires (4 wires, 2 & 2 without a schematic I'm assuming they're paired). I get 6.9V DC at both pairs, when I run the motor test, 1 set drops to 0v, the other stays constant at 6.9V
Is that a strange voltage? I figured it would be 12V
#5 5 years ago
The gray/yellow wire, witch comes from J141-2 should be 12v, and goes to both. The other wire for solenoid #39 is yellow/white and goes to J110-4, and for solenoid #40 it is green/white and goes to J110-5.
#6 5 years ago
I have 14v at gray/yellow, 9.7v at Green/brown & 10.7 at Tan/red - the connector coming from the backbox to the stepper board. Measurements taken on the pins of the stepper board connector while not plugged into the board.
#7 5 years ago
So is the yellow/white replaced by the green/brown, and green/white replaced by the tan/red? Do these wires go to the solenoids or come from J110-4 and J110-5?
#8 5 years ago
Sorry, I just went across the connector and measured what voltages I had. Yellow/White has continuity with the J110-4 as does the Green/White at J110-5. Measuring these two wires for voltages yields a reading of 0v.
#9 5 years ago
Here's a picture where you can see the basics of the operation of the wheel.
Depending on the inputs A and B, the exits of P2 are 0 volt or 9 Volt dc.
#10 5 years ago
Ok, sounds like the 9-10v on one and 0v on the other is a good reading. But you said earlier you only got 6.9v, so where's the voltage drop. Low voltage probably won't let the motor run.
#11 5 years ago
Maybe one channel is working and gives a lower reading because of the high-speed pulsing,
and the channel other is stuck to 0 and 9 volts.
In that case, one of the data inputs could have bad connection.
#12 5 years ago
All of the diodes check out (tested in circuit), only one that's possibly off if D10 - measures 664. Most all of the resistors are within tolerance, except the 100K, that reading is at about 60K.
Anything else I should check for? I've reflowed solder on the input connector.
Thank you for all the help so far everyone.
#13 5 years ago
With some reservation because I have no Scared Stiff or stepperPCB to verify.
D10 and D9 are in serie and should measure about the same.
Resistor 100K reading 60K, is that R13 ? That one is for Opto-receiver and not motor-control. does opto work?
During the spider motor test, PDB J110-4 and J110-5 are pulsing at high speed from high to low.
This signal is connected to steppermotorcontrolboard J1-4 and J1-5.
High = 12Volt Low = 0Volt. If there's no pulse, possible U3 of PowerDriverBoard is bad
If there is a pulse signal, you could perform this test to find out if the stepperPCB is working:
-machine on
-disconnect PDB J110
-jumper J1-7 (GND) to J1-4 (input A). Does the motor move 1 step ? and/or
-jumper J1-7 (GND) to J1-5 (input B). Does the motor move 1 step ?
You mention you hear the motor humming so I assume settings A.2 30 is set to "NO"
#14 5 years ago
Well, the problem is resolved. Ended up being the 5 pin molex connector in the back box. Replaced the housings and repinned all the wires and now it works like a charm. Some testing with alligator clips & my meter helped me isolate this.
Thanks to everyone that helped. There are a lot of really smart people that post on here.
Joe
7 months later
#15 4 years ago
Hoi Zaza,
Its sounds you know how it works the spider motor, i tried some stuff bud it wont turn.
please help.
#16 4 years ago
Help is on the way, but it's almost sleeping time over here but will first finish my drink.
What's the problem with the spider ?
#18 4 years ago
Ok, will look there
$ 79.95
Jackson, MI
