Hi! I purchased a Bond Gottlieb system 80 not working. The boards in the game looked in bad shape. So I replaced the power supply board and the driver board and the mpu with new rottendog boards. I then powerd the game up. All the lights came on. The game would not take any credits. I looked at the coin door and noticed the credit switchs were bent up and the slam tilt switch wires were cut. I adjusted the credit switchs and connected the slam switch on the door. I also checked the tilt switch under the playfield to make sure it was open and the roll ball switch was open. Then I gave a few credits and started a game. The ball then kicked out of the out hole. At this point the jets and the side bumpers and the flippers will not activate. I then checked the pop up bumpers and the score switchs on the playfield and they all worked. I also checked the diodes under the playfield and on the bottom of the cabnet and they were all fine accept one underneath the playfield. I did notice on the old mpu board that they had defeated the slam tilt. Yesterday I went back and looked at the game and I tied the two wires together on the slam tilt. Then I went to give the game credits and start a game and the game would not give credits. I then turned game off and turned back on and the game playfield lights went off and the display was lit. I hooked the wires back directly to the slam switch again and the playfield lights come on but wont let me give it credits. Any suggestions would be appreciated. Thanks
