We're back!
After a disaster in our datacenter took down our server, we are now running Pinside on a brand new server. However, things may not work as expected as we are still polishing the playfield and adjusting some switches! We might be switching to maintenance mode a few times. Please see this forum topic for more info.
(Topic ID: 246372)
Tech help: Meteor backbox controlled lamps not working
By westofrome
1 year ago
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 1 year ago by westofrome
    #1 1 year ago
    Looking to troubleshoot the backbox controlled lamps in Meteor. All other game controlled lamps work fine, but not the five backbox ones (Tilt, Shoot Again, Game Over, High Score to Date, Match). They do not light at all in controlled lamp test. All the backbox GI works fine.
    I have tested the controlled lamp bulbs and they all work in other backbox GI sockets.
    When I jump the SCRs to ground, I get the following behavior:
    When jumping any of the SCRs except for the Shoot Again one, BOTH the jumped lamp and Shoot Again light very dimly. If I pull one of the lamps, the other goes out entirely. When I jump the Shoot Again SCR, nothing happens. I replaced a SCR (actually MCR, Q33, for Game Over) but got the same behavior.
    I began testing continuity from the tab to the connector, started with Tilt, and got successful continuity. So something is off with the circuit.
    There are some wire hacks I note below in the picture. The Shoot Again, Match, and Game over wires were all cut at some point and then twisted/soldered back together - but I confirmed they are the correct wire color matches. I will fix this with shrink tube but this doesn't appear to be the source of the problem.
    I located two other cut wires - one blue and one yellow, noted below, but no obvious loose end to match them with.
    Thanks for any help!
    #2 1 year ago
    On your rectifier board, J3-6 should be a blue wire. This is what powers the feature lamps on the back board insert. It should daisy chain from one to the next on one side of the lamp sockets with the individual different colored wires on the other. Check for power at each one in lamp test mode.
    Shawn
    #3 1 year ago
    Oh, and I would start where the insert plugs into the main harness. Lots of potential for trouble there.
    #4 1 year ago
    Thanks! I resoldered the blue wire to the chain and all the controlled lamps work properly now.
    Dave
