Right side works perfectly. Reset the data in utilities, and it hits the left ramp almost flawlessly. However, left side inop.
Left side switches all work (inlane, opto, proximity). Right side eddy sensor board good; left side eddy sensor board no good. Switched boards, and nothing worked. Concluded that good right board revealed another issue on left side, and on right side the left side board was again confirmed inop. Switched the small socketed IC on the boards without effect. Reset ribbon cable between CPU and PDB also.
Since three of the four wires (ground, +12V and Col. 4) going to the boards are the same, I checked the continuity from the spitter to the two connectors and everything had continuity. On the board side of that splitter, there are two WHT-VIO wires. One coming from J208-8, and I have not yet figured out where that other one goes.
Since the right side works, and the left side has continuity of the wiring from splitter to connector at eddy sensor, I checked the continuity of the WHT-VIO wire at ROW 7 on the switch matrix from J208-8 to the splitter, and there is continuity.
So, left side eddy sensor is bad, and another problem exists prior to the wiring coming out of J208-8 or where the other WHT-VIO leads.
Next steps include 1) switching PDB from my CV into the MB and then CPU if necessary, 2) hitting all the solder points on the left side eddy sensor board, 3) figuring out where that other WHT-VIO wire goes, and 4) turn to the schematics and trace the circuit for J208-8.
If there is anything that I may have missed or not done correctly from the above description in working on the wiring from the boards down to the proximity sensor switches at the playfield, please let me know.
Any thoughts on where to go from here? Thanks as always.
Dan
