Tech Help: Leaf Switch Causing Game To Reboot
By PBaller22
2 years ago
Stats
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 2 years ago by LTG
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
#1 2 years ago
Greetings all,
I have a JY machine that was working normally, then one day decided to randomly reboot during play. Troubleshot the problem enough to determine that it's happening when a certain leaf switch is triggered on a standup target in the crane area. When it happens, a sound effect actually plays and then DMD flashes "raindrops" (at least that's what I'm calling it...random diagonal lines evenly spaced across the DMD). Flippers go dead...almost like it's a tilt. Then when ball re-enters the trough, it starts up again. Plays fine until that standup is hit. Any ideas why a leaf switch would cause a game to reboot when it makes contact?
#2 2 years ago
Could be that switch, or others.
Look your switches over. Be sure they are wired right, diode facing the right direction, and nothing is shorting switch wiring.
LTG : )™
#3 2 years ago
Gotcha. I recently attempted to replace a different switch, which was unsuccessful (in that after I did it the switch still didn't work). My guess is that the diode on that one is going the wrong way. The problem didn't start until I replaced that switch. Seems like a good place to start at least. Thanks, Llyod!
#4 2 years ago
Start there. Look at it. Williams used a basic wiring scheme. White wire there ( and what ever color stripe ) and with black end of diode. Green wire there. Silver band end of diode there.
Same on every switch, so easy to compare to others.
LTG : )™
Ewe22 Security PIC Chips
KAHR.US Circuits
$ 229.99
PinballBulbs
$ 129.00
LED OCD
$ 36.99
Lee's Parts
$ 40.00
Mount Clemens, MI
Note: This is an old thread. The last post was made to it 1,008 days ago. Resurrecting old threads is not necessarily a bad thing, if you think the topic is still relevant and/or your post is beneficial to it (e.g. following up on something). In other cases, it might be better to create a new topic.
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
