This is my first EM. Have been reading up on how these work and the startup sequence.
the machines powers up and the game over light is lit. ball is in game. I add credit, and it accepts it. I press start, the machine (not in any order) resets score reels to zero, one credit subtracted, ball unit moves to what appears to be ball one, drop targets move up, but then ...
the machine keeps on clicking... (one small relay in the head, some big 10 unit relay under the playfield keeps on resetting and some wheel with stacks (8 or so) of switches keep cycling until i power off the machine.
if I look at the power up sequence, i think it does almost all of it... could it be a switch in the big 10 unit relay that is not registering on or off? not sure what this SWITCH ON BLUE is from the sequence below. I have no idea where to start. any help would be appreciated.
start sequence i got from another thread.
"COIN RELAY IS ENERGIZED AT SCORE MOTOR INDEX CAM SWITCH C, THRU SWITCH ON COIN RELAY, GAME RELAY, ZERO SWITCH ON CREDIT UNIT AND CREDIT BUTTON SWITCH.
SWITCHES ON COIN RELAY WILL ENERGIZE GAME*OVER RELAY, ENERGIZE RESET RELAY, ENERGIZE A&:B AND C& TARGET RESET COILS, ENERGIZE GAME RELAY LATCH COIL THRU WIPER ON BALL COUNT UNIT (AT ZERO POSITION), AND PULSE BALL COUNT RESET AND S.U. COILS THRU SWITCH D ON GAME RELAY.
SWITCHES ON RESET RELAY WILL RUN SCORE MOTOR, PULSE SCORE RESET RELAY, THRU SCORE MOTOR IMPULSE CAM SWITCH, ENERGIZE BONUS RELAY THRU SWITCH ON "1 TO 10 SET-UP RELAY't, AND ENERGIZE 1 TO 10
RELAY BANK RESET COIL. (115 VOLTS).
SWITCHES ON SCORE RESET RELAY WILL PULSE 4 SCORE DRUM UNITS UNTIL THEY REACH ZERO.
SWITCHES ON BONUS RELAY \-TILL RUN SCORE MOTOR, HOLD RESET RE- LAY IN, PULSE STRIKE BONUS UNIT RESET COIL, PULSE 1 TO 10 BONUS DRUM UNIT, PULSE EJECT ADVANCE DRUM UNIT IF ZERO SWITCH IS CLOSED, ENERGIZE 1 TO 10 HOLD RELAY AND 1 TO 10 SET-UP RELAY.
BONUS RELAY DROPS OUT WHEN STRIKE BONUS UNIT IS RESET TO ZERO AND THE "1 TO 10 SET-UP RELAY" IS ENERGIZED (AT SCORE MOTOR
- CAM SWITCH 6A). NOW WHEN THE SCORE MOTOR REACHES INDEX POSITION, THE OUTHOLE RELAY \-JILL ENERGIZE.
SWITCHES ON OUTHOLE RELAY WILL RUN SCORE MOTOR, ENERGIZE
1 TO 10 RELAY BANK RESET COIL (115 VOLTS) THRU SWITCH ON BLUE
STAR RELAY, AND ENERGIZE BALL RELEASE COIL TO PROPEL BALL TO- WARD PLUNGER."
