Hey all, my Demo Man is giving me a switch 33 trough 3 error message. I don't have the manual. it doesn't seem to affect gameplay much other than sending an extra ball into play once in a while. Any advice would be appreciated.
hey steve,
i'm not near my DM now (in different town). you can dowload the manual for free here;
http://www.ipdb.org/search.pl?any=demolition+man&searchtype=quick
i'd check your ball trough. make sure it's not pitted by balls first (common with 90's williams pins). if so you can buy a 'sleeve' to put in it/and or get some emery cloth to smooth out the grooves. it sounds like an opto error, probably need to take a qtip to clean, or adjust, or replace the transmitter and/or receiver. hope this helps, i had a similar problems with my DH.
Likely an opto on your trough board, start with a good cleaning and then test the optos in the test mode by running something thin through the trough to see if they are all registering (should go in order). If #3 is not registering after cleaning it will likely need to be replaced, this can be done either by removing the old opto and resoldering on a new one, or by purchasing new ball trough boards (much more expensive)
This page was printed from https://pinside.com/pinball/forum/topic/tech-help-dm-switch-33-trough-3-error and we tried optimising it for printing. Some page elements may have been deliberately hidden.
