Hey guys - pretty much a noob on anything that is not mechanical. My magnet does not work and I have the switch 42 error - which I think is an opto that activates the magnet - Is that correct?
If correct - it appears as though the opto is located on either side of the magnet in an area that can only be accessed by taking almost the entire pf apart?! - I have attached a pic where you can see the magnet and a hole where I assume one half of the opto resides. there is a similar hole across from it.
If all of the above is correct - is there a better way to fix this? Can I pull the magnet out from below and get at the optos?
Any help is certainly appreciated!
