Hey BSD Owners....need your help.
Could a few of you look into your BSD and describe the pinout of the connector connected directly to the transformer (from the box that has the power switch in the front of the machine)? This is a nine pin connector. Looking at it so that the connection "tab" is on the left, I'd expect
White wire ---> O O O <--- Black wire
--> O O O <--
Jumper wire Jumper wire between these pins
--> O O O <--
Basically, white wire on the left pin column and black wire on the right pin column, and two jumper wires connecting the lower pins of each pin column.
Pictures would be great too.
Thank You
