yes that is glue. They do that for the big caps so over time they do not get loose or get crack solder joints. Most large Caps are filter caps so probably not the problem. Only way to test is with a ESR meter. Look for raised heads on the smaller caps or leaking (usually brownish) liquid from the other CAPS.
First step would be to check connectors and the test point voltages. See below.
http://www.techdose.com/projects/Stern-Pinball-SB100-Sound-Board/346/page4.html
I'd already checked all the voltages. They are all spot on. I'm working on checking the connectors now.
This page was printed from https://pinside.com/pinball/forum/topic/tech-help-blown-capacitor and we tried optimising it for printing. Some page elements may have been deliberately hidden.
