(Topic ID: 239485)
Tech: Guns N‘ Roses intermittent drop target issue
By HighwayStarr
1 year ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by jake35
#1 1 year ago
Recently my 1st drop target in the right side GNR bank hasn’t been resetting properly every time . Mechanically all seems fine but the far left target won’t always stay up when the ball drains or I begin a new game. Sometimes it does and sometimes it does not. i’ve attached a video below. Manually with the play field up it appears to move freely with out binding up and down just like the other 2 . Any suggestions ? This video is 4 seconds and is right as the ball has drained and the next ball it kicked up into play . Thanks
#2 1 year ago
Replace the target - the tab on the back that holds it up on the edge of the plate under the playfield is probably worn.
#3 1 year ago
I think you should adjust the lift bar.
I don't know if you can adjust the bar, but it looks like the coil doesn't pull it high enough.
That is what you should test, lifting the bar with the plunger of the coil only.
#4 1 year ago
Thanks guys ... weekend is coming up I’ll check it out
#5 1 year ago
mine has one that fell and wont' come back up, it's laying sideways. I need to look into whether it broke or can be reattached
$ 24.95
$ 279.95
Pin Stadium Pinball LEDs
$ 27.00
PinSound
€ 95.00
FlipperLED
