(Topic ID: 223202)
Tech: GTB Super Mario Lamp Issue
By TheCnyPinGuy
1 year ago
  • 17 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by TheCnyPinGuy
#1 1 year ago
Hi
Working on my SMB and I have a slight mirroring effect on my lamps
Like for Example: the shoot again lamp in test lights castle 1 on the apron
And the Cherry Insert slightly lights a tortoise shell
I have never really had any issues with my System 3 pins and I have 3 in the collection
Any starting point would be helpful
The game plays fine but that slight effect reminds me of like a ghosting led but these are 47s
I can post a video if that would help
Thank you in advance
#3 1 year ago
I guess no one knows how to fix Gottliebs.......
#4 1 year ago
I suggested possible diode issues earlier.
If that doesn't pan out, then there's the driver board--either transistors or the driver chips.
Grounding could also be a possibility, although breaks in grounds general cause various things to not work at all.
#5 1 year ago
I'm guessing it's the shell in the left? If you have the manual refer to pg 53 lamp matrix. It looks like shell #1, bonus chance (cherries), and shoot again are in same column. Shoot again is also in the same row as castle 1.
Check the wiring on the lamps to start.
Or you could try swapping the driver board from one of your other system 3's to determine if it's the board.
#6 1 year ago
I am still digging per Force Flows Suggestions
Just wanted some other options on the trouble shooting
I plan on swapping my driver board from a Barbwire to isolate the issue
I appreciate and thank everyone for their time
Will continue to dig until the issue is resolved and report back so others down the road can also fix a similar lamp issue
#7 1 year ago
Video for the Post to help show what is happening
I am investigating the U Lamp that is not working as ForceFlow Mentioned Diodes
#8 1 year ago
So poking around I found this
A green wire from Adv Super to Cherry
Should I cut it ??
Still looking
#9 1 year ago
Another jumper ..
#10 1 year ago
Okay after I clipped the jumpers and whatnot I noted 8 lamps are dead
Lamp - Description
13 - 10,000
17 - 1,000
20 - Bonus Chance “Cherries”
31 - s “U” per
67 - Extra Ball
43 - Island 1 #2 (light box)
44 - Island 2 #1 (light box)
B4 - Island 6 #1 (light box)
I do not have a manual if anyone does if you could snap me a picture of the lamp matrix to see what’s up would be great
I am swapping the drivers tomorrow morning to see if it corrects all my lamps
Thank you all again
James
#11 1 year ago
Quoted from TheCnyPinGuy:
Lamp - Description
13 - 10,000
17 - 1,000
31 - s “U” per
67 - Extra Ball
Thank you all again
James
OK so after removing the jumpers you no longer get 2 lights turning on at the same time anymore?
If that's the case then the next step is to replace the diodes on the light sockets that aren't working. Just saw a handful of dead ones in a Mario Andretti.
There doesn't appear to be a pattern to the rows/columns so I think it's likely just bad individual diodes.
#12 1 year ago
And also check for cracked solder joints.
#13 1 year ago
Are they standard 1N4004 or would other diodes also fit the bill like Bally Williams
Thanks all
#14 1 year ago
That is correct
Once I cut off the 2 jumpers that issue of the mirroring (2 bulbs or more at once) issue went away also they got brighter since the bulbs didn’t share power anymore
#15 1 year ago
Yes, they should be.
#16 1 year ago
SUCCESS !!
Jumpered a diode in the U socket and she lights up
I’ll keep going
Thank you all for the help esp ForceFlow as he stated bad diodes from the beginning
#17 1 year ago
Yes
All the non working lamps are result of bad diodes
I did not check the lamp boards just sockets but after 8 sockets rechecked with a new diode it’s safe to assume that if I check the board with my diode on a jumper they would work as they should
Thank you again ForceFlow & kbliznick
$ 249.00
Gweem's Mods
3,800 (OBO)
Greenville, SC
$ 12.00
Yorktown Parts and Equip
$ 6.00
German-Pinball-Modular
Comet Pinball
$ 17.00
$ 72.00
PinWorlds
$ 4.00
Z-connector (24 pin) Out of stock
Professor Pinball
Music City Pinball
$ 42.00
The MOD Couple
$ 89.99
$ 229.99
$ 12.00
Slap Save Creations
$ 90.00
Geeteoh Electronics
$ 269.00
Pinball Pro
$ 15.75
Cabinet Parts
Tilted Pinball
