Yeah I thought he said replaced z15 new so I figured no input = no output. That is why i mentioned the z33.
As I said DS3 (Z33 - pin 4) is responsible for DIP SW25 to SW32 string AND "some" lamps , IMHO it's
easier to check those lamps
I think those lamps are L8 ; L9 ; L10 and L11 - on PF - "P" ; "O" ; "O" ; "L" lamps, if they work DS3 is present .
(correct me if I'm "wrong" in lamp positioning )
I "tip on" continuity or grounded problem
Quoted from hassellcastle:Still havent had a chance to check the board yet. But i will tell you the P O O L lights work.
Quoted from cro_pinman:As I said DS3 (Z33 - pin 4) is responsible for DIP SW25 to SW32 string AND "some" lamps , IMHO it's
easier to check those lampsI think those lamps are L8 ; L9 ; L10 and L11 - on PF - "P" ; "O" ; "O" ; "L" lamps, if they work DS3 is present .
(correct me if I'm "wrong" in lamp positioning )I "tip on" continuity or grounded problem
Yeah so if those lamps work I would feel comfortable in that the Z33 pin 4 is functioning fine. But if no continuity to the z15( ie trace broken) then no input. He needs to verify seeing single at Z15 pin 13.
It is close I feel it.
Whaaa whhhooooo. Fixed!
Thank you gentlemen.
Problem was bad solder job underside the socket of Z15 at pin 13. It wasnt making continuity. I ran a small jumper on the back of the board all fixed now.
Kudos to you all.
Alright! cro_pinman had it wired on page 1, give the man a thumbs up guys. Glad you got it working Craig.
Steve
Ok, I have seen this issue several times; replaced about everything and still no luck on the DIP switch.
One simple thought; did you try and replace the 1N4148 diode that's under the DIP?
Yes, they do break at times
I am having a similar problem with my newly acquired Caveman.
It also works 100% except the MATCH FEATURE will not work even though it is set to ON.
I have moved the DIP switch back and forth.
I'm thinking I may have a problem similar to hassellcastle.
I have not tried to set DIP SWITCH 25 from 5 Balls to 3 Balls as mine is set to OFF.
The Game ADJUSTEMENTS page Chris posted is identical to the setting page on Caveman from what I see.
So did this issue affect the last 8 switch settings that hassellcastle was experiencing with Bad Girls?
I see that would mean that those last 8 dip switches (25-32) would default to OFF even if they were set to ON?
On Caveman, Switch 29 controls setting of : EXTRA BALL (ON) or REPLAY (OFF).
I am getting EXTRA BALL cause my SWITCH 29 in ON.
So do I possibly have a different issue than hassellcastle?
This page was printed from https://pinside.com/pinball/forum/topic/tech-gottlieb-system-80b-dipswitch-settings-not-working/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
