Are there any Gottlieb System 3 guru's lurking in the tech forum???
I've got a Street Fighter 2 that I'm rebuilding, had to piece together a board set. I purchased an untested Audio Board (from another SF2), an AUX Audio Board (from rescue 911) and two AUX Power Supply (both NOS from PBR).
The first AUX power board that I installed was accidently smoked (like a dummy I plugged the DMD power plug into the AUX power board header and POOF the board needs a rebuild, magic smoke and all). So while that one is on the backburner for repair, I purchased another NOS Aux power board from PBR.
When I install the trio of boards, and power the game up, there is no "screech", amp pop, nothing. Sometimes the LED's come on the Audio boards (and stay on), other times they don't come on at all. The new AUX power board has a questionable odor as if it burned up as well, however I can't find any bad components on it.
Where should I be looking? What do these boards do when they boot properly? From what I understand, they screech on startup, and then the LED's blink on/off to signify they are working.
Thanks for any help
